public void LockSection( SectionDefinition sectionDef )
Public Sub LockSection( _ ByVal sectionDef As SectionDefinition _ )
Parameters
- sectionDef
- The definition of the section to lock
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
| System.ArgumentNullException | Section is null |
| System.ArgumentException | Section not found in the collection of sections |
| System.InvalidOperationException | Section cannot be locked |
var mapView = MapView.Active;
await QueuedTask.Run(() =>
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
voxelLayer.SetSectionContainerExpanded(true);
voxelLayer.SetLockedSectionContainerExpanded(true);
voxelLayer.SetLockedSectionContainerVisibility(true);
//Use the SelectedVariableProfile to get the sections
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
//get the selected section
var section = mapView.GetSelectedSections().FirstOrDefault();
if (section == null)
section = volume.GetSections().FirstOrDefault();
return;
//Lock the section (Creates a locked section, deletes
//the section)
//if (voxelLayer.CanLockSection(section))
// voxelLayer.LockSection(section);
if (volume.CanLockSection(section))
volume.LockSection(section);
