ArcGIS.Core.Data Namespace / TableDefinition Class / GetAliasName Method
    GetAliasName Method (TableDefinition)
    Gets the alias name of the definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAliasName() As String
    public string GetAliasName()
    Return Value
    The alias name of the definition.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
