ArcGIS.Core.Data Namespace / TableDefinition Class / GetDefaultSubtypeCode Method
    Gets the integer value representing the table's default subtype code. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDefaultSubtypeCode() As Integer
    public int GetDefaultSubtypeCode()
    Return Value
    The integer value representing the table's default subtype code.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
