ArcGIS.Core.Data Namespace / TableDefinition Class / GetEditorField Method
    Gets the name of the editor field. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetEditorField() As String
    public string GetEditorField()
    Return Value
    The name of the editor field.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
