ArcGIS.Core.Data Namespace / TableDefinition Class / GetGlobalIDField Method
    Gets the name of the GlobalID field. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetGlobalIDField() As String
    public string GetGlobalIDField()
    Return Value
    The name of the GlobalID field.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
