ArcGIS.Core.Data Namespace / TableDefinition Class / GetSubtypeField Method
    Gets the name of the field used to define subtypes. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSubtypeField() As String
    public string GetSubtypeField()
    Return Value
    The name of the field used to define subtypes.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the table is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
