ArcGIS.Core.Data Namespace / TableDefinition Class / HasObjectID Method
    HasObjectID Method
    Gets a value indicating whether this table has a field containing ObjectIDs. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function HasObjectID() As Boolean
    public bool HasObjectID()
    Return Value
    true if this table has a field containing ObjectIDs; otherwise, false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    If the table has an ObjectID, it is registered with the geodatabase
    Requirements
