ArcGIS.Core.Data Namespace / UnknownDatastore Class
Members Example
    Represents an unknown or currently not supported data repository.
    Object Model
    UnknownDatastore ClassConnector ClassDatastoreProperties ClassSQLSyntax Class
    Syntax
    public sealed class UnknownDatastore : Datastore, System.IDisposable
    Public NotInheritable Class UnknownDatastore
       Inherits Datastore
       Implements System.IDisposable
    Example
    Obtaining Geodatabase from Project Item
      var currentProject = Project.Current;
      if (currentProject == null)
        return;
      await QueuedTask.Run(() =>
        IEnumerable<GDBProjectItem> gdbProjectItems = currentProject.GetItems<GDBProjectItem>();
        foreach (GDBProjectItem gdbProjectItem in gdbProjectItems)
          using (Datastore datastore = gdbProjectItem.GetDatastore())
            //Unsupported datastores (non File GDB and non Enterprise GDB) will be of type UnknownDatastore
            if (datastore is UnknownDatastore)
              continue;
            Geodatabase geodatabase = datastore as Geodatabase;
            // Use the geodatabase.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Datastore
             ArcGIS.Core.Data.UnknownDatastore
    Requirements
