ArcGIS.Desktop.Mapping Namespace / BasicFeatureLayer Class / RemoveDefinitionQuery Method
Index of a DefinitionQuery in the list of DefinitionQueries.
    RemoveDefinitionQuery Method (BasicFeatureLayer)
    Removes the definition query at the specified index. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub RemoveDefinitionQuery( _
       ByVal index As Integer _
    public void RemoveDefinitionQuery(
       int index
    Parameters
    index
    Exceptions
    ExceptionDescription
    Index is invalid or out of bounds.
    DefinitionQueries is empty.
    Requirements
