ArcGIS.Desktop.Mapping Namespace / TIFFColorMode Enumeration
Example Example
    Specifies the number of bits used to describe color for TIFF.
    Syntax
    Members
    MemberDescription
    EightBitAdaptivePalette 8-bit Adaptive Palette.
    EightBitGrayScale 8-bit Grayscale.
    FortyBitCMYKWithAlpha 40-bit CMYK with Alpha.
    OneBitMonochromeThreshold 1-bit Monochrome Threshold.
    ThirtyTwoBitCMYK 32-bit true color CMYK.
    ThirtyTwoBitWithAlpha 32-bit with Alpha.
    TwentyFourBitTrueColor 24-bit True Color.
    Example
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      string filePath = @"Path and file name for the output export file";
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        HasWorldFile = true,
        ImageCompression = TIFFImageCompression.LZW
      //Set up map series export options
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Export on the worker thread
      //Check to see if the path is valid and export
      if (TIFF.ValidateOutputFilePath())
        await QueuedTask.Run(() => layout.Export(TIFF, MSExportOptions_TIFF));  //Export to TIFF
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.TIFFColorMode
    Requirements
