ArcGIS.Core.Geometry Namespace / MinorOrMajor Enumeration
    Indicates whether the arc is a minor or major arc. An arc is minor if the central angle is less than PI radians (180 degrees) and major otherwise. Used with EllipticArcBuilderEx.CreateCircularArc.
    Syntax
    Members
    MemberDescription
    Major An arc is a major arc if the central angle is greater than or equal to PI radians (180 degrees)
    Minor An arc is a minor arc if the central angle is less than PI radians (180 degrees)
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.MinorOrMajor
    Requirements
