ArcGIS.Core.Geometry Namespace / OffsetType Enumeration
    Offset options for use with the GeometryEngine.Offset method.
    Syntax
    Members
    MemberDescription
    Bevel Corners should be beveled - constructs the offset curve to be beveled about an obtuse angle.
    Miter Corners should be mitered - constructs the offset curve to form a point about an obtuse angle.
    Round Corners should be rounded - constructs the offset curve to be rounded about an obtuse angle
    Square Corners should be squared.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.OffsetType
    Requirements
