ArcGIS.Core.Geometry Namespace / SegmentType Enumeration
Example Example
    Describes the type of line segment. See the Segment.SegmentType property.
    Syntax
    Members
    MemberDescription
    Bezier A third degree cubic Bezier curve. A non-linear segment defined by four control points. The Bezier curve starts at control point 0 (start point) and ends at control point 3 (end point) The start point and control point 1 define the tangent at the start point. Control point 2 and the end point define the tangent at the end point. The length of these tangent lines and position of the 4 control points determines the shape of the created Bezier curve.
    EllipticArc An elliptic arc is the portion of the boundary of a 2D ellipse that connects two points.
    Line A straight line segment between a start point and end point.
    Example
    Enumerate the parts of a Polyline
      ReadOnlyPartCollection polylineParts = polyline.Parts;
      // enumerate the segments to get the length
      double len = 0;
      IEnumerator<ReadOnlySegmentCollection> segmentsPolyline = polylineParts.GetEnumerator();
      while (segmentsPolyline.MoveNext())
        ReadOnlySegmentCollection seg = segmentsPolyline.Current;
        foreach (Segment s in seg)
          len += s.Length;
          // perhaps do something specific per segment type
          switch (s.SegmentType)
            case SegmentType.Line:
              break;
            case SegmentType.Bezier:
              break;
            case SegmentType.EllipticArc:
              break;
      // or use foreach pattern
      foreach (var part in polyline.Parts)
        foreach (var segment in part)
          len += segment.Length;
          switch (segment.SegmentType)
              break;
              break;
              break;
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.SegmentType
    Requirements
