ArcGIS.Core.Geometry Namespace / WktExportFlags Enumeration
Example Example
    Specifies the flags that control the behavior of the GeometryEngine.ExportToWKT method.
    Syntax
    Members
    MemberDescription
    WktExportDefaults Exports the geometry as is based on its type. Attributes such as Z and M values are exported.
    WktExportFailIfNotSimple Throws an exception if the geometry is not topologically simple. Applies only to Polygon and Polyline geometry types.
    WktExportLineString Exports a MultiLineString with one LineString as a LineString.
    WktExportMultiLineString Exports a LineString as a MultiLineString
    WktExportMultipoint Exports a Point as a Multipoint.
    WktExportMultiPolygon Exports a Polygon as a MultiPolygon.
    WktExportPoint Exports a Multipoint with one Point as a Point.
    WktExportPolygon Exports a MultiPolygon with one Polygon as a Polygon.
    WktExportStripMs Removes M values from the exported shape.
    WktExportStripZs Removes Z values from the exported shape.
    Example
    Import and Export Geometries to well-known Text
      // create a point with z, m
      MapPoint point = MapPointBuilderEx.CreateMapPoint(
               100, 200, 300, 400, SpatialReferences.WebMercator);
      // set the flags
      WktExportFlags wktExportFlags = WktExportFlags.WktExportDefaults;
      WktImportFlags wktImportFlags = WktImportFlags.WktImportDefaults;
      // export and import
      string wktString = GeometryEngine.Instance.ExportToWKT(wktExportFlags, point);
      MapPoint importPointGeom = GeometryEngine.Instance.ImportFromWKT(
            wktImportFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
      double x = importPointGeom.X;       // x = 100
      double y = importPointGeom.Y;       // y = 200
      bool hasZ = importPointGeom.HasZ;   // hasZ = true
      double z = importPointGeom.Z;       // z = 300
      bool hasM = importPointGeom.HasM;   // hasM = true
      double m = importPointGeom.M;       // m = 400
      // export without z
      WktExportFlags exportFlagsNoZ = WktExportFlags.WktExportStripZs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ, point);
      hasZ = importPointGeom.HasZ;  // hasZ = false
      z = importPointGeom.Z;        // z = 0
      // export without m
      WktExportFlags exportFlagsNoM = WktExportFlags.WktExportStripMs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoM, point);
      hasM = importPointGeom.HasM;  // hasM = false
      m = importPointGeom.M;        // m = Nan
      // export without z, m
        exportFlagsNoZ | exportFlagsNoM, point);
    Import and Export Geometries to well-known Binary
      // create a polyline
      List<Coordinate2D> coords = new List<Coordinate2D>
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      polyline = PolylineBuilderEx.CreatePolyline(
                  coords, SpatialReferences.WGS84);
      WkbExportFlags wkbExportFlags = WkbExportFlags.WkbExportDefaults;
      WkbImportFlags wkbImportFlags = WkbImportFlags.WkbImportDefaults;
      byte[] buffer = GeometryEngine.Instance.ExportToWKB(wkbExportFlags, polyline);
      geometry = GeometryEngine.Instance.ImportFromWKB(
                     wkbImportFlags, buffer, SpatialReferences.WGS84);
      Polyline importPolyline = geometry as Polyline;
      // alternatively, determine the size for the buffer
      int bufferSize = GeometryEngine.Instance.GetWKBSize(wkbExportFlags, polyline);
      buffer = new byte[bufferSize];
      // export
      bufferSize = GeometryEngine.Instance.ExportToWKB(
                      wkbExportFlags, polyline, ref buffer);
      // import
      importPolyline = GeometryEngine.Instance.ImportFromWKB(
               wkbImportFlags, buffer, SpatialReferences.WGS84) as Polyline;
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.WktExportFlags
    Requirements
