ArcGIS.Core.Geometry Namespace / Coordinate2D Structure / Y Property
Example
    Y Property (Coordinate2D)
    Gets or sets the Y-component.
    Syntax
    public double Y {get; set;}
    Public Property Y As Double
    Example
    Determine grid convergence for a SpatialReference at a given point
      Coordinate2D coordinate = new Coordinate2D(10, 30);
      double angle = SpatialReferences.WGS84.GetConvergenceAngle(coordinate);
      // angle = 0
      SpatialReference srUTM30N = SpatialReferenceBuilder.CreateSpatialReference(32630);
      coordinate.X = 500000;
      coordinate.Y = 550000;
      angle = srUTM30N.GetConvergenceAngle(coordinate);
      // angle = 0
      MapPoint pointWGS84 = MapPointBuilderEx.CreateMapPoint(10, 50, SpatialReferences.WGS84);
      MapPoint pointUTM30N = GeometryEngine.Instance.Project(
        pointWGS84, srUTM30N) as MapPoint;
      coordinate = (Coordinate2D)pointUTM30N;
      // get convergence angle and convert to degrees
      angle = srUTM30N.GetConvergenceAngle(coordinate) * 180 / Math.PI;
      // angle = 10.03
    Create an N-sided regular polygon
      // <summary>
      // Create an N-sided regular polygon.  A regular sided polygon is a polygon that is equiangular (all angles are equal in measure)
      // and equilateral (all sides are equal in length).  See https://en.wikipedia.org/wiki/Regular_polygon
      // </summary>
      // <param name="numSides">The number of sides in the polygon.</param>
      // <param name="center">The center of the polygon.</param>
      // <param name="radius">The distance from the center of the polygon to a vertex.</param>
      // <param name="rotation">The rotation angle in radians of the start point of the polygon. The start point will be
      // rotated counterclockwise from the positive x-axis.</param>
      // <returns>N-sided regular polygon.</returns>
      // <exception cref="ArgumentException">Number of sides is less than 3.</exception>
      static Polygon CreateRegularPolygon(int numSides, Coordinate2D center, double radius, double rotation)
        if (numSides < 3)
          throw new ArgumentException();
        Coordinate2D[] coords = new Coordinate2D[numSides + 1];
        double centerX = center.X;
        double centerY = center.Y;
        double x = radius * Math.Cos(rotation) + centerX;
        double y = radius * Math.Sin(rotation) + centerY;
        Coordinate2D start = new Coordinate2D(x, y);
        coords[0] = start;
        double da = 2 * Math.PI / numSides;
        for (int i = 1; i < numSides; i++)
          x = radius * Math.Cos(i * da + rotation) + centerX;
          y = radius * Math.Sin(i * da + rotation) + centerY;
          coords[i] = new Coordinate2D(x, y);
        coords[numSides] = start;
        return PolygonBuilderEx.CreatePolygon(coords);
    Requirements
