ArcGIS.Core.Geometry Namespace / EllipticArcSegment Class / QueryCoords Method
The center point of the ellipse.
The start angle in radians measured from the rotated X-axis.
The central angle in radians measuring the span of the arc from startAngle to endAngle. A positive value corresponds to counterclockwise orientation.
The angle in radians by which the ellipse is rotated from the X-axis. A positive value corresponds to counterclockwise rotation.
The length of the semi-major axis.
The length of the semi-minor axis.
Example
    QueryCoords Method (EllipticArcSegment)
    Copies the center coordinate, start angle, central angle, rotation angle, semi-major/semi-minor axes into the method parameters.
    Syntax
    Public Sub QueryCoords( _
       ByRef centerCoordinate As Coordinate2D, _
       ByRef startAngle As Double, _
       ByRef centralAngle As Double, _
       ByRef rotationAngle As Double, _
       ByRef semiMajorAxis As Double, _
       ByRef semiMinorAxis As Double _
    Parameters
    centerCoordinate
    startAngle
    centralAngle
    rotationAngle
    semiMajorAxis
    semiMinorAxis
    Remarks
    Angles are in radians.
    Example
    Construct a Circle
      // Construct a circle with center at (-1,-1), radius = 2, and oriented clockwise.
      // Use a builderEx convenience method or use a builderEx constructor.
      Coordinate2D centerPtCoord = new Coordinate2D(-1, -1);
      // Builder convenience methods don't need to run on the MCT.
      EllipticArcSegment circle = EllipticArcBuilderEx.CreateCircle(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      // circle.IsCircular = true
      // circle.IsCounterClockwise = false
      // circle.IsMinor = false
      double startAngle, rotationAngle, centralAngle, semiMajor, semiMinor;
      Coordinate2D actualCenterPt;
      circle.QueryCoords(out actualCenterPt, out startAngle, out centralAngle, out rotationAngle, out semiMajor, out semiMinor);
      // semiMajor = 2.0
      // semiMinor = 2.0
      // startAngle = PI/2
      // centralAngle = -2*PI
      // rotationAngle = 0
      // endAngle = PI/2
      // This EllipticArcBuilderEx constructor doesn't need to run on the MCT.
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      EllipticArcSegment otherCircle = builder.ToSegment();
    Elliptic Arc Properties
      // retrieve the curve's control points
      EllipticArcSegment arc = EllipticArcBuilderEx.CreateEllipticArcSegment(ellipticArcSegment);
      MapPoint startPt = arc.StartPoint;
      MapPoint endPt = arc.EndPoint;
      Coordinate2D centerPt = arc.CenterPoint;
      bool isCircular = arc.IsCircular;
      bool isMinor = arc.IsMinor;
      bool isCounterClockwise = arc.IsCounterClockwise;
      bool isCurve = arc.IsCurve;
      double len = arc.Length;
      double ratio = arc.MinorMajorRatio;
      double semiMajorAxis, semiMinorAxis;
      // get the axes
      arc.GetAxes(out semiMajorAxis, out semiMinorAxis);
      // or use the properties
      // semiMajorAxis = arc.SemiMajorAxis;
      // semiMinorAxis = arc.SemiMinorAxis;
      double startAngle, centralAngle, rotationAngle;
      // or use QueryCoords to get complete information
      arc.QueryCoords(out centerPt, out startAngle, out centralAngle, out rotationAngle, out semiMajorAxis, out semiMinorAxis);
      // use properties to get angle information
      //double endAngle = arc.EndAngle;
      //centralAngle = arc.CentralAngle;
      //rotationAngle = arc.RotationAngle;
      //startAngle = arc.StartAngle;
    Requirements
