ArcGIS.Core.Geometry Namespace / EllipticArcSegment Class / IsCounterClockwise Property
Example
    Gets if this elliptic arc segment is counter-clockwise.
    Syntax
    public bool IsCounterClockwise {get;}
    Public ReadOnly Property IsCounterClockwise As Boolean
    Example
    Elliptic Arc Properties
      // retrieve the curve's control points
      EllipticArcSegment arc = EllipticArcBuilderEx.CreateEllipticArcSegment(ellipticArcSegment);
      MapPoint startPt = arc.StartPoint;
      MapPoint endPt = arc.EndPoint;
      Coordinate2D centerPt = arc.CenterPoint;
      bool isCircular = arc.IsCircular;
      bool isMinor = arc.IsMinor;
      bool isCounterClockwise = arc.IsCounterClockwise;
      bool isCurve = arc.IsCurve;
      double len = arc.Length;
      double ratio = arc.MinorMajorRatio;
      double semiMajorAxis, semiMinorAxis;
      // get the axes
      arc.GetAxes(out semiMajorAxis, out semiMinorAxis);
      // or use the properties
      // semiMajorAxis = arc.SemiMajorAxis;
      // semiMinorAxis = arc.SemiMinorAxis;
      double startAngle, centralAngle, rotationAngle;
      // or use QueryCoords to get complete information
      arc.QueryCoords(out centerPt, out startAngle, out centralAngle, out rotationAngle, out semiMajorAxis, out semiMinorAxis);
      // use properties to get angle information
      //double endAngle = arc.EndAngle;
      //centralAngle = arc.CentralAngle;
      //rotationAngle = arc.RotationAngle;
      //startAngle = arc.StartAngle;
    Requirements
