ArcGIS.Core.Geometry Namespace / Envelope Class / ToEsriShape Method / ToEsriShape(Byte[]) Method
The buffer to which the geometry will be written. The buffer must be large enough to hold the Esri shapefile formatted version of the input geometry.
Example
    Converts this envelope into an Esri shape formatted binary byte buffer. Note that the returned buffer will represent a polygon as there is not an Esri shape buffer for envelope geometry type.
    Syntax
    public override long ToEsriShape(
       ref byte[] shapeBuffer
    Public Overloads Overrides NotOverridable Function ToEsriShape( _
       ByRef shapeBuffer() As Byte _
    ) As Long
    Parameters
    shapeBuffer
    Return Value
    The number of bytes used to store this instance in the input shapeBuffer.
    Example
    Import and Export Geometries to EsriShape
      // create an envelope
      List<MapPoint> coordsZM = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(1001, 1002, 1003, 1004),
      MapPointBuilderEx.CreateMapPoint(2001, 2002, Double.NaN, 2004),
      MapPointBuilderEx.CreateMapPoint(3001, -3002, 3003, 3004),
      MapPointBuilderEx.CreateMapPoint(1001, -4002, 4003, 4004)
      Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(
                 coordsZM[0], coordsZM[2], SpatialReferences.WGS84);
      // export and import
      EsriShapeExportFlags exportFlags = EsriShapeExportFlags.EsriShapeExportDefaults;
      EsriShapeImportFlags importFlags = EsriShapeImportFlags.EsriShapeImportDefaults;
      byte[] buffer = GeometryEngine.Instance.ExportToEsriShape(exportFlags, envelope);
      Polygon importedPolygon = GeometryEngine.Instance.ImportFromEsriShape(
                     importFlags, buffer, envelope.SpatialReference) as Polygon;
      Envelope importedEnvelope = importedPolygon.Extent;
      // export without z,m
              EsriShapeExportFlags.EsriShapeExportStripZs |
              EsriShapeExportFlags.EsriShapeExportStripMs, envelope);
              importFlags, buffer, SpatialReferences.WGS84) as Polygon;
      bool hasZ = importedEnvelope.HasZ;      // hasZ = false
      bool hasM = importedEnvelope.HasM;      // hasM = false
      // export with shapeSize
      int bufferSize = GeometryEngine.Instance.GetEsriShapeSize(
      buffer = new byte[bufferSize];
      bufferSize = GeometryEngine.Instance.ExportToEsriShape(
                                   exportFlags, envelope, ref buffer);
      // or use the envelope and envelopeBuilderEx classes
      buffer = envelope.ToEsriShape();
      // buffer represents a polygon as there is not an envelope Esri shape buffer
      // EnvelopeBuilderEx.FromEsriShape takes a polygon Esri shape buffer and returns the extent of the polygon.
      importedEnvelope = EnvelopeBuilderEx.FromEsriShape(buffer);
    Requirements
