ArcGIS.Core.Geometry Namespace / GeographicTransformation Class / Create Method / Create(String,Boolean) Method
The well-known text of the geographic transformation to be created.
(Optional) Default is true. If false, the created transformation is inverted.
Example
    Creates a GeographicTransformation instance from a well-known text string.
    Syntax
    Public Overloads Shared Function Create( _
       ByVal wkt As String, _
       Optional ByVal transformForward As Boolean _
    ) As GeographicTransformation
    Parameters
    wkt
    transformForward
    Return Value
    Example
    Create Geographic Transformation
      // create from wkid
      GeographicTransformation gt1478 =
        ArcGIS.Core.Geometry.GeographicTransformation.Create(1478);
      string name = gt1478.Name;
      string wkt = gt1478.Wkt;
      int wkid = gt1478.Wkid;
      // create from wkt
      GeographicTransformation another_gt1478 =
           ArcGIS.Core.Geometry.GeographicTransformation.Create(wkt);
      // inverse
      GeographicTransformation inverse_gt148 =
                     another_gt1478.GetInverse() as GeographicTransformation;
      bool isForward = inverse_gt148.IsForward;
    Requirements
