ArcGIS.Core.Geometry Namespace / Geometry Class / ToEsriShape Method / ToEsriShape(Byte[]) Method
The buffer to which the geometry will be written. The buffer must be large enough to hold the Esri shapefile formatted version of the input geometry.
    Converts this geometry into an Esri shape formatted binary byte buffer and returns the size of the shapeBuffer.
    Syntax
    public abstract long ToEsriShape(
       ref byte[] shapeBuffer
    Public Overloads MustOverride Function ToEsriShape( _
       ByRef shapeBuffer() As Byte _
    ) As Long
    Parameters
    shapeBuffer
    Return Value
    The number of bytes used to store this instance in the input shapeBuffer.
    Requirements
