ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Area Method
The geometry of which the area will be calculated.
Example
    Area Method (GeometryEngine)
    Gets the area of the geometry. This is a planar measurement using 2D Cartesian mathematics to compute the area.
    Syntax
    Public Function Area( _
       ByVal geometry As Geometry _
    ) As Double
    public double Area(
       Geometry geometry
    Parameters
    geometry
    Return Value
    The computed area in the same units as the geometry's spatial reference unit. If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    Example
    Build a donut polygon
      List<Coordinate2D> outerCoordinates = new List<Coordinate2D>();
      outerCoordinates.Add(new Coordinate2D(10.0, 10.0));
      outerCoordinates.Add(new Coordinate2D(10.0, 20.0));
      outerCoordinates.Add(new Coordinate2D(20.0, 20.0));
      outerCoordinates.Add(new Coordinate2D(20.0, 10.0));
      // define the inner polygon as anti-clockwise
      List<Coordinate2D> innerCoordinates = new List<Coordinate2D>();
      innerCoordinates.Add(new Coordinate2D(13.0, 13.0));
      innerCoordinates.Add(new Coordinate2D(17.0, 13.0));
      innerCoordinates.Add(new Coordinate2D(17.0, 17.0));
      innerCoordinates.Add(new Coordinate2D(13.0, 17.0));
      PolygonBuilderEx pbEx = new PolygonBuilderEx(outerCoordinates);
      Polygon donutEx = pbEx.ToGeometry() as Polygon;
      double areaEx = donutEx.Area;       // area = 100
      pbEx.AddPart(innerCoordinates);
      areaEx = donutEx.Area;    // area = 84.0
      areaEx = GeometryEngine.Instance.Area(donutEx);    // area = 84.0
    Determine area of a polygon
      var g1 = PolygonBuilderEx.FromJson("{\"rings\": [ [ [0, 0], [10, 0], [10, 10], [0, 10] ] ] }");
      double d = GeometryEngine.Instance.Area(g1);
      // d = -100.0         //negative due to wrong ring orientation
      d = GeometryEngine.Instance.Area(GeometryEngine.Instance.SimplifyAsFeature(g1));
      // d = 100.0        // feature has been simplifed; ring orientation is correct
    Requirements
