ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Boundary Method
Specifies the input geometry.
Example
    Boundary Method (GeometryEngine)
    Calculates the boundary of the input geometry.
    Syntax
    Public Function Boundary( _
       ByVal geometry As Geometry _
    ) As Geometry
    public Geometry Boundary(
       Geometry geometry
    Parameters
    geometry
    Return Value
    The geometry that represents the boundary of the input geometry. For Point - returns an empty point. For Multipoint - returns an empty point. For Envelope - returns a polyline, that bounds the envelope. For Polyline - returns a multipoint, using OGC specification (includes path endpoints, using mod 2 rule). For Polygon - returns a polyline that bounds the polygon by adding all rings of the polygon to a polyline.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The method is not implemented for GeometryBag.
    Remarks
    If the input geometry is not known-simple, then the operation will be performed on a simplified copy of the geometry.
    GeometryEngine Boundary
    Example
    Determine the boundary of a multi-part Polygon
      // create a donut polygon.  Must use the PolygonBuilderEx object
      List<Coordinate2D> outerPts =
        new Coordinate2D(10.0, 10.0),
        new Coordinate2D(10.0, 20.0),
        new Coordinate2D(20.0, 20.0),
        new Coordinate2D(20.0, 10.0),
      List<Coordinate2D> innerPts =
        new Coordinate2D(13.0, 13.0),
        new Coordinate2D(17.0, 13.0),
        new Coordinate2D(17.0, 17.0),
        new Coordinate2D(13.0, 17.0),
      Polygon donut = null;
      // add the outer points
      PolygonBuilderEx pb = new(outerPts);
      // add the inner points (note they are defined anticlockwise)
      pb.AddPart(innerPts);
      // get the polygon
      donut = pb.ToGeometry();
      // get the boundary
      Geometry g = GeometryEngine.Instance.Boundary(donut);
      Polyline boundary = g as Polyline;
      // use the boundary...
    Requirements
