ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Buffer Method / Buffer(IEnumerable<Geometry>,Double) Method
Specifies the input geometries.
The distance (in the unit of the geometry's spatial reference) to buffer the geometries.
Example
    Creates buffers at the specified distance around the given geometries. Will union the results of all buffers.
    Syntax
    Public Overloads Function Buffer( _
       ByVal geometries As IEnumerable(Of Geometry), _
       ByVal distance As Double _
    ) As Geometry
    Parameters
    geometries
    distance
    Return Value
    The polygon that represents the buffered area.
    Exceptions
    ExceptionDescription
    Input geometry enumerable is null or empty.
    The method is not implemented for GeometryBag.
    The buffer distance must be a valid floating point number.
    Remarks
    The returned polygon is the union of all the buffered geometries.
    If the buffer distance is zero and the input geometry is a polygon or an envelope, then a polygon is created from the input geometries.
    If the distance is less than or equal to zero and the input geometry is not a polygon or an envelope, then an empty polygon is created.
    The spatial reference of the output geometries is the first not null or unknown spatial reference found in the list of geometries. All other geometries are projected to this spatial reference, if necessary. If no such spatial reference is found, then the unknown spatial reference is used if it is found in the list. Otherwise, the spatial reference is null.
    Example
    Zoom to a specified point
      double x = -122.45;
      double y = 37.75;
      double buffer_size = 0.1;
      //Create a point
      var pt = MapPointBuilderEx.CreateMapPoint(x, y,
                     SpatialReferenceBuilder.CreateSpatialReference(4326));
      //Buffer it - for purpose of zoom
      var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
      //do we need to project the buffer polygon?
      if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference))
        //project the polygon
        poly = GeometryEngine.Instance.Project(poly, MapView.Active.Map.SpatialReference);
      // Must run on MCT.
      QueuedTask.Run(() =>
        //Zoom - add in a delay for animation effect
        MapView.Active.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Buffer multiple MapPoints
      // creates a buffer around each MapPoint
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
        MapPointBuilderEx.CreateMapPoint(1.0, 2.0),
        MapPointBuilderEx.CreateMapPoint(2.0, 2.0),
        MapPointBuilderEx.CreateMapPoint(2.0, 1.0),
      Geometry ptsBuffer = GeometryEngine.Instance.Buffer(pts, 0.25);
      Polygon bufferResult = ptsBuffer as Polygon;      // bufferResult will have 4 parts
    Buffer many different Geometry Types
      List<Coordinate2D> coords =
        new Coordinate2D(1, 2), new Coordinate2D(3, 4), new Coordinate2D(4, 2),
        new Coordinate2D(5, 6), new Coordinate2D(7, 8), new Coordinate2D(8, 4),
        new Coordinate2D(9, 10), new Coordinate2D(11, 12), new Coordinate2D(12, 8),
        new Coordinate2D(10, 8), new Coordinate2D(12, 12), new Coordinate2D(14, 10)
      List<Geometry> manyGeometries =
        MapPointBuilderEx.CreateMapPoint(coords[9]),
        PolylineBuilderEx.CreatePolyline([coords[0], coords[1], coords[2]], SpatialReferences.WGS84),
        PolylineBuilderEx.CreatePolyline([coords[3], coords[4], coords[5]]),
        PolygonBuilderEx.CreatePolygon([coords[6], coords[7], coords[8]])
      Geometry manyGeomBuffer = GeometryEngine.Instance.Buffer(manyGeometries, 0.25);
    Requirements
