ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ConvexHull Method
The geometry to create a convex hull of.
Example
    ConvexHull Method (GeometryEngine)
    Constructs the convex hull of the geometry.
    Syntax
    Public Function ConvexHull( _
       ByVal geometry As Geometry _
    ) As Geometry
    public Geometry ConvexHull(
       Geometry geometry
    Parameters
    geometry
    Return Value
    A polygon that represents the convex hull of the input geometry. If the input geometry is empty, then an empty polygon is returned.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    Remarks
    The convex hull of a geometry is the minimal bounding polygon such that all outer angles are convex. The ConvexHull of a point is the point itself.
    GeometryEngine ConvexHull
    Example
    Determine convex hull
        // convex hull around a point - returns a point
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(2.0, 2.0);
        Geometry hull = GeometryEngine.Instance.ConvexHull(pt);
        MapPoint hullPt = hull as MapPoint;
        // nullPt.X = 2
        // hullPt.Y = 2
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(2.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(2.0, 1.0),
        // convex hull around a multipoint - returns a polygon
        // build a multiPoint
        Multipoint multiPoint = MultipointBuilderEx.CreateMultipoint(list);
        hull = GeometryEngine.Instance.ConvexHull(multiPoint);
        Polygon hullPoly = hull as Polygon;
        // hullPoly.Area = 1
        // hullPoly.PointCount = 5
        // convex hull around a line - returns a polyline or polygon
        List<MapPoint> polylineList = [MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(2.0, 2.0)];
        // 2 point straight line
        polyline = PolylineBuilderEx.CreatePolyline(polylineList);
        hull = GeometryEngine.Instance.ConvexHull(polyline);
        Polyline hullPolyline = hull as Polyline;
        // hullPolyline.Length = Math.Sqrt(2)
        // hullPolyline.PointCount = 2
        // 3 point angular line
        polylineList.Add(MapPointBuilderEx.CreateMapPoint(2.0, 1.0));
        // hullPoly.Length = 2 + Math.Sqrt(2)
        // hullPoly.Area = 0.5
        // hullPoly.PointCount = 4
        // convex hull around a polygon - returns a polygon
        // simple polygon
        Polygon poly = PolygonBuilderEx.CreatePolygon(list);
        hull = GeometryEngine.Instance.ConvexHull(poly);
        // hullPoly.Length = 4.0
        // hullPoly.Area = 1.0
        // polygon with concave angles
        List<MapPoint> funkyList =
      MapPointBuilderEx.CreateMapPoint(1.5, 1.5),
        Polygon funkyPoly = PolygonBuilderEx.CreatePolygon(funkyList);
        hull = GeometryEngine.Instance.ConvexHull(funkyPoly);
        // hullPoly.Points[0] = 1.0, 1.0
        // hullPoly.Points[1] = 1.0, 2.0
        // hullPoly.Points[2] = 2.0, 2.0
        // hullPoly.Points[3] = 2.0, 1.0
        // hullPoly.Points[4] = 1.0, 1.0
    Requirements
