ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Crosses Method
The base geometry.
The comparison geometry.
Example
    Crosses Method (GeometryEngine)
    Returns true if geometry1 crosses geometry2.
    Syntax
    Public Function Crosses( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if the geometry1 crosses geometry2.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    A polyline crosses another polyline if they share only points in common, at least one of which is not an endpoint. A polyline crosses a polygon if at least one path of the polyline is partly inside the polygon and partly outside.
    GeometryEngine Crosses
    Example
    Determine if two geometries cross
        // pt on pt
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
        MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(2.0, 2.0);
        bool crosses = GeometryEngine.Instance.Crosses(pt, pt2);         // crosses = false
        crosses = GeometryEngine.Instance.Crosses(pt, pt);               // crosses = false
        // pt and line
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
        Polyline line1 = PolylineBuilderEx.CreatePolyline(list);
        crosses = GeometryEngine.Instance.Crosses(line1, pt2);           // crosses = false
        crosses = GeometryEngine.Instance.Crosses(pt2, line1);           // crosses = false
        // end pt of line
        crosses = GeometryEngine.Instance.Crosses(line1, pt);            // crosses = false
        // pt and polygon
        List<MapPoint> polyPts =
          MapPointBuilderEx.CreateMapPoint(3.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 2.0),
        Polygon poly1 = PolygonBuilderEx.CreatePolygon(polyPts);
        crosses = GeometryEngine.Instance.Crosses(poly1, pt);              // crosses = false
        crosses = GeometryEngine.Instance.Crosses(pt, poly1);              // crosses = false
        // line and line
        List<MapPoint> list2 =
          MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
        Polyline line2 = PolylineBuilderEx.CreatePolyline(list2);
        crosses = GeometryEngine.Instance.Crosses(line1, line2);           // crosses = true
        // line and polygon
        crosses = GeometryEngine.Instance.Crosses(poly1, line1);           // crosses = true
        // polygon and polygon
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(4, 4));
        Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
        crosses = GeometryEngine.Instance.Crosses(poly1, poly2);           // crosses = false
    Requirements
