ArcGIS.Core.Geometry Namespace / GeometryEngine Class / DensifyByDeviation Method
The geometry to be densified.
The maximum distance in meters that the output geometry can deviate from the input geometry.
    DensifyByDeviation Method (GeometryEngine)
    Densifies the specified geometry.
    Syntax
    Public Function DensifyByDeviation( _
       ByVal geometry As Geometry, _
       ByVal maxDeviationMeters As Double _
    ) As Geometry
    public Geometry DensifyByDeviation(
       Geometry geometry,
       double maxDeviationMeters
    Parameters
    geometry
    maxDeviationMeters
    Return Value
    Returns the densified geometry. If the input geometry is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Remarks
    The densify operation adds vertices to the input geometry.
    Requirements
