ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Disjoint Method
The base geometry.
The comparison geometry.
Example
    Disjoint Method (GeometryEngine)
    Returns true if geometry1 and geometry2 are disjoint.
    Syntax
    Public Function Disjoint( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    public bool Disjoint(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if geometry1 and geometry2 are disjoint.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    Two geometries are disjoint if they don't have any points in common. Equivalent to not Intersects.
    GeometryEngine Disjoint
    Example
    Determine if two Geometries are disjoint
        // pt on pt
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
        MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(2.0, 2.5);
        bool disjoint = GeometryEngine.Instance.Disjoint(pt, pt2);       // result is true
        MultipointBuilderEx mpb = new();
        mpb.AddPoint(pt);
        mpb.AddPoint(pt2);
        Multipoint multiPoint = mpb.ToGeometry();
        disjoint = GeometryEngine.Instance.Disjoint(multiPoint, pt);     // result is false
        // pt and line
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
        Polyline line1 = PolylineBuilderEx.CreatePolyline(list);
        disjoint = GeometryEngine.Instance.Disjoint(line1, pt2);       // result is true
        disjoint = GeometryEngine.Instance.Disjoint(pt2, line1);       // result is true
        // end pt of line
        disjoint = GeometryEngine.Instance.Disjoint(line1, pt);        // result is false
        // pt and polygon
        List<MapPoint> polyPts =
          MapPointBuilderEx.CreateMapPoint(3.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 2.0),
        Polygon poly1 = PolygonBuilderEx.CreatePolygon(polyPts);
        disjoint = GeometryEngine.Instance.Disjoint(poly1, pt);          // result is true
        disjoint = GeometryEngine.Instance.Disjoint(pt, poly1);          // result is true
        // line and line
        List<MapPoint> list2 =
          MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
        Polyline line2 = PolylineBuilderEx.CreatePolyline(list2);
        disjoint = GeometryEngine.Instance.Disjoint(line1, line2);         // result is false
        // line and polygon
        disjoint = GeometryEngine.Instance.Disjoint(poly1, line1);         // result is false
        disjoint = GeometryEngine.Instance.Disjoint(line1, poly1);         // result is false
        // polygon and polygon
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(4, 4));
        Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
        disjoint = GeometryEngine.Instance.Disjoint(poly1, poly2);         // result is false
        // disjoint3D
        SpatialReference sr = SpatialReferences.WGS84;
        MapPoint pt3D_1 = MapPointBuilderEx.CreateMapPoint(1, 1, 1, sr);
        MapPoint pt3D_2 = MapPointBuilderEx.CreateMapPoint(2, 2, 2, sr);
        MapPoint pt3D_3 = MapPointBuilderEx.CreateMapPoint(1, 1, 2, sr);
        MultipointBuilderEx mpbEx = new();
        mpbEx.AddPoint(pt3D_1);
        mpbEx.AddPoint(pt3D_2);
        mpbEx.HasZ = true;
        multiPoint = mpbEx.ToGeometry();
        disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_2);     // disjoint = false
        disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_3);     // disjoint = true
    Requirements
