ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Disjoint3D Method
The base geometry.
The comparison geometry.
Example
    Disjoint3D Method (GeometryEngine)
    Returns true if geometry1 and geometry2 are disjoint in a 3-dimensional manner.
    Syntax
    Public Function Disjoint3D( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    public bool Disjoint3D(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if the geometry1 and geometry2 are disjoint.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Either geometry1 or geometry2 is not Z-Aware.
    Remarks
    Two geometries are 3D disjoint, if they are Z-Aware and don't have any points in common. The geometries must be Z-Aware or an exception will be thrown.
    Example
    Determine if two Geometries are disjoint
        // pt on pt
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
        MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(2.0, 2.5);
        bool disjoint = GeometryEngine.Instance.Disjoint(pt, pt2);       // result is true
        MultipointBuilderEx mpb = new();
        mpb.AddPoint(pt);
        mpb.AddPoint(pt2);
        Multipoint multiPoint = mpb.ToGeometry();
        disjoint = GeometryEngine.Instance.Disjoint(multiPoint, pt);     // result is false
        // pt and line
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
        Polyline line1 = PolylineBuilderEx.CreatePolyline(list);
        disjoint = GeometryEngine.Instance.Disjoint(line1, pt2);       // result is true
        disjoint = GeometryEngine.Instance.Disjoint(pt2, line1);       // result is true
        // end pt of line
        disjoint = GeometryEngine.Instance.Disjoint(line1, pt);        // result is false
        // pt and polygon
        List<MapPoint> polyPts =
          MapPointBuilderEx.CreateMapPoint(3.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 2.0),
        Polygon poly1 = PolygonBuilderEx.CreatePolygon(polyPts);
        disjoint = GeometryEngine.Instance.Disjoint(poly1, pt);          // result is true
        disjoint = GeometryEngine.Instance.Disjoint(pt, poly1);          // result is true
        // line and line
        List<MapPoint> list2 =
          MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
        Polyline line2 = PolylineBuilderEx.CreatePolyline(list2);
        disjoint = GeometryEngine.Instance.Disjoint(line1, line2);         // result is false
        // line and polygon
        disjoint = GeometryEngine.Instance.Disjoint(poly1, line1);         // result is false
        disjoint = GeometryEngine.Instance.Disjoint(line1, poly1);         // result is false
        // polygon and polygon
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(4, 4));
        Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
        disjoint = GeometryEngine.Instance.Disjoint(poly1, poly2);         // result is false
        // disjoint3D
        SpatialReference sr = SpatialReferences.WGS84;
        MapPoint pt3D_1 = MapPointBuilderEx.CreateMapPoint(1, 1, 1, sr);
        MapPoint pt3D_2 = MapPointBuilderEx.CreateMapPoint(2, 2, 2, sr);
        MapPoint pt3D_3 = MapPointBuilderEx.CreateMapPoint(1, 1, 2, sr);
        MultipointBuilderEx mpbEx = new();
        mpbEx.AddPoint(pt3D_1);
        mpbEx.AddPoint(pt3D_2);
        mpbEx.HasZ = true;
        multiPoint = mpbEx.ToGeometry();
        disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_2);     // disjoint = false
        disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_3);     // disjoint = true
    Requirements
