ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Distance Method
The first geometry.
The second geometry.
Example
    Distance Method (GeometryEngine)
    Measures the planar distance between two geometries.
    Syntax
    Public Function Distance( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Double
    Parameters
    geometry1
    The first geometry.
    geometry2
    Return Value
    The distance between the two input geometries in the same unit as the spatial reference of the input geometries. If either of the input geometries is empty, then NaN is returned.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    GeometryEngine Distance
    Example
    Determine distance between two Geometries
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(2.0, 2.0);
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(4.0, 2.0);
      // pt and pt
      double d = GeometryEngine.Instance.Distance(pt1, pt2);         // d = Math.Sqrt(2)
      // pt and multipoint
      List<MapPoint> multiPts = [pt2, pt3];
      Multipoint multiPoint = MultipointBuilderEx.CreateMultipoint(multiPts);
      d = GeometryEngine.Instance.Distance(pt1, multiPoint);         // d = Math.Sqrt(2)
      // pt and envelope
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(pt1, pt2);
      d = GeometryEngine.Instance.Distance(pt1, env);                // d = 0
      // pt and polyline
      List<MapPoint> polylinePts = [MapPointBuilderEx.CreateMapPoint(2.0, 1.0), pt2];
      polyline = PolylineBuilderEx.CreatePolyline(polylinePts);
      d = GeometryEngine.Instance.Distance(pt1, polyline);             // d = 1.0
      // pt and polygon
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(3.0, 3.0), MapPointBuilderEx.CreateMapPoint(5.0, 5.0));
      Polygon poly = PolygonBuilderEx.CreatePolygon(env2);
      d = GeometryEngine.Instance.Distance(pt1, poly);                 // d = Math.Sqrt(8)
      // envelope and polyline
      d = GeometryEngine.Instance.Distance(env, polyline);             // d = 0
      // polyline and polyline
      List<MapPoint> polylineList = [MapPointBuilderEx.CreateMapPoint(4, 3), MapPointBuilderEx.CreateMapPoint(4, 4)];
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(polylineList);
      d = GeometryEngine.Instance.Distance(polyline, polyline2);           // d = Math.Sqrt(5)
      // polygon and polygon
      Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
      d = GeometryEngine.Instance.Distance(poly, poly2);                 // d = Math.Sqrt(2)
    Requirements
