ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Expand Method / Expand(Envelope,Double,Double,Double,Boolean) Method
The envelope to expand or shrink.
The scale factor along the X-axis. In other words, the amount to expand or shrink the width of the envelope.
The scale factor along the Y-axis. In other words, the amount to expand or shrink the height of the envelope.
The scale factor along the Z-axis. In other words, the amount to expand or shrink the depth of the envelope.
If asRatio = false, the expansion is additive. If asRatio = true, the expansion is multiplicative.
Example
    Expands or shrinks the envelope in a 3-dimensional manner.
    Syntax
    Public Overloads Function Expand( _
       ByVal envelope As Envelope, _
       ByVal dx As Double, _
       ByVal dy As Double, _
       ByVal dz As Double, _
       ByVal asRatio As Boolean _
    ) As Envelope
    Parameters
    envelope
    dx
    dy
    dz
    asRatio
    Return Value
    The scaled envelope.
    Exceptions
    ExceptionDescription
    Envelope is null or empty.
    This geometry is not Z-Aware.
    Spatial reference of envelopeis an image coordinate system.
    Remarks
    The envelope must be Z-Aware or else an exception will be thrown.
    If asRatio is set to true, dx, dy and dz must be greater than or equal to zero. In this case, if the user wants to increase the envelope width by 10%, then dx = 1.1. On the other hand, if the user wants to decrease the width by 10%, then dx = 0.9.
    Example
    Expand envelopes
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(100.0, 100.0, 500.0, 500.0);
      // env.HasZ = false
      Envelope result = GeometryEngine.Instance.Expand(env, 0.5, 0.5, true);
      // result.Center = 300, 300
      // result.XMin = 200
      // result.YMin = 200
      // result.XMax = 400
      // result.YMax = 400
      result = GeometryEngine.Instance.Expand(env, 100, 200, false);
      // result.XMin = 0
      // result.YMin = -100
      // result.XMax = 600
      // result.YMax = 700
      try
        // expand in 3 dimensions
        result = GeometryEngine.Instance.Expand(env, 0.5, 0.5, 0.5, true);
      catch (InvalidOperationException)
        // the geometry is not Z-Aware
      // expand a 3d envelope
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(100, 100, 100);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(200, 200, 200);
      env = EnvelopeBuilderEx.CreateEnvelope(pt1, pt2);
      // env.HasZ = true
      // result.Center = 150, 150, 150
      // result.XMin = 125
      // result.YMin = 125
      // result.ZMin = 125
      // result.XMax = 175
      // result.YMax = 175
      // result.ZMax = 175
    Requirements
