ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ExportToEsriShape Method / ExportToEsriShape(EsriShapeExportFlags,Geometry,Byte[]) Method
A combination of EsriShapeExportFlags which determines how the geometry is exported. Uses esriShapeExportNewArcFormat for circular and elliptic arcs.
The geometry to write to the buffer.
The buffer to which the geometry will be written. The buffer must be large enough to hold the Esri shapefile formatted version of the input geometry.
Example
    Writes an Esri shapefile formatted version of the input geometry to the specified buffer.
    Syntax
    Public Overloads Function ExportToEsriShape( _
       ByVal exportFlags As EsriShapeExportFlags, _
       ByVal geometry As Geometry, _
       ByRef buffer() As Byte _
    ) As Integer
    public int ExportToEsriShape(
       EsriShapeExportFlags exportFlags,
       Geometry geometry,
       ref byte[] buffer
    Parameters
    exportFlags
    geometry
    buffer
    Return Value
    The exact number of bytes written to the buffer.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The method is not implemented for GeometryBag.
    Example
    Import and Export Geometries to EsriShape
      // create an envelope
      List<MapPoint> coordsZM = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(1001, 1002, 1003, 1004),
      MapPointBuilderEx.CreateMapPoint(2001, 2002, Double.NaN, 2004),
      MapPointBuilderEx.CreateMapPoint(3001, -3002, 3003, 3004),
      MapPointBuilderEx.CreateMapPoint(1001, -4002, 4003, 4004)
      Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(
                 coordsZM[0], coordsZM[2], SpatialReferences.WGS84);
      // export and import
      EsriShapeExportFlags exportFlags = EsriShapeExportFlags.EsriShapeExportDefaults;
      EsriShapeImportFlags importFlags = EsriShapeImportFlags.EsriShapeImportDefaults;
      byte[] buffer = GeometryEngine.Instance.ExportToEsriShape(exportFlags, envelope);
      Polygon importedPolygon = GeometryEngine.Instance.ImportFromEsriShape(
                     importFlags, buffer, envelope.SpatialReference) as Polygon;
      Envelope importedEnvelope = importedPolygon.Extent;
      // export without z,m
              EsriShapeExportFlags.EsriShapeExportStripZs |
              EsriShapeExportFlags.EsriShapeExportStripMs, envelope);
              importFlags, buffer, SpatialReferences.WGS84) as Polygon;
      bool hasZ = importedEnvelope.HasZ;      // hasZ = false
      bool hasM = importedEnvelope.HasM;      // hasM = false
      // export with shapeSize
      int bufferSize = GeometryEngine.Instance.GetEsriShapeSize(
      buffer = new byte[bufferSize];
      bufferSize = GeometryEngine.Instance.ExportToEsriShape(
                                   exportFlags, envelope, ref buffer);
      // or use the envelope and envelopeBuilderEx classes
      buffer = envelope.ToEsriShape();
      // buffer represents a polygon as there is not an envelope Esri shape buffer
      // EnvelopeBuilderEx.FromEsriShape takes a polygon Esri shape buffer and returns the extent of the polygon.
      importedEnvelope = EnvelopeBuilderEx.FromEsriShape(buffer);
    Requirements
