ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ExportToWKB Method / ExportToWKB(WkbExportFlags,Geometry,Byte[]) Method
A combination of WkbExportFlags which determines how the geometry is exported.
The geometry to write to the buffer.
The buffer to which the geometry will be written. The buffer must be large enough to hold the OGC well-known binary version of the input geometry.
Example
    Writes an OGC well-known binary formatted version of the input geometry to the specified buffer.
    Syntax
    Public Overloads Function ExportToWKB( _
       ByVal exportFlags As WkbExportFlags, _
       ByVal geometry As Geometry, _
       ByRef buffer() As Byte _
    ) As Integer
    public int ExportToWKB(
       WkbExportFlags exportFlags,
       Geometry geometry,
       ref byte[] buffer
    Parameters
    exportFlags
    geometry
    buffer
    Return Value
    The exact number of bytes written to the buffer.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The method is not implemented for GeometryBag or Multipatch.
    The method is not implemented for geometry with curves.
    Remarks
    Does not support curves. Also, note that if the geometry contains ID information, this property will not be preserved in the export operation. The WKB OGC standard does not contain the ID property.
    Example
    Import and Export Geometries to well-known Binary
      // create a polyline
      List<Coordinate2D> coords = new List<Coordinate2D>
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      polyline = PolylineBuilderEx.CreatePolyline(
                  coords, SpatialReferences.WGS84);
      WkbExportFlags wkbExportFlags = WkbExportFlags.WkbExportDefaults;
      WkbImportFlags wkbImportFlags = WkbImportFlags.WkbImportDefaults;
      // export and import
      byte[] buffer = GeometryEngine.Instance.ExportToWKB(wkbExportFlags, polyline);
      geometry = GeometryEngine.Instance.ImportFromWKB(
                     wkbImportFlags, buffer, SpatialReferences.WGS84);
      Polyline importPolyline = geometry as Polyline;
      // alternatively, determine the size for the buffer
      int bufferSize = GeometryEngine.Instance.GetWKBSize(wkbExportFlags, polyline);
      buffer = new byte[bufferSize];
      // export
      bufferSize = GeometryEngine.Instance.ExportToWKB(
                      wkbExportFlags, polyline, ref buffer);
      // import
      importPolyline = GeometryEngine.Instance.ImportFromWKB(
               wkbImportFlags, buffer, SpatialReferences.WGS84) as Polyline;
    Requirements
