ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GeodesicSector Method
The geodesic sector parameter that describes how to draw the geodesic sector.
The spatial reference of the sector.
Example
    GeodesicSector Method (GeometryEngine)
    The function returns a piecewise approximation of a geodesic ellipse (or geodesic circle, if SemiAxis1Length = SemiAxis2Length). Constructs a geodesic ellipse centered on the specified point. If this method is used to generate a polygon or a polyline, the result may have more than one part, depending on the size of the sector and its position relative to the horizon of the coordinate system. When the method generates a polyline or a multipoint, the result vertices lie on the boundary of the ellipse. When a polygon is generated, the interior of the polygon is the interior of the sector, however the boundary of the polygon may contain segments from the spatial reference horizon, or from the GCS extent.
    Syntax
    Parameters
    parameter
    spatialReference
    Return Value
    The geometry that contains sector of the geodesic ellipse.
    Exceptions
    ExceptionDescription
    Only Polygon, Polyline and Multipoint are supported for GeodesicSectorParameter.OutGeometryType.
    Either parameter or spatialReference is null.
    The spatial reference is an image coordinate system.
    Example
    GeodesicSector
      GeodesicSectorParameter param = new()
        ArcVertexCount = 50,
        AxisDirection = Math.PI / 4,
        Center = new Coordinate2D(0, 0),
        LinearUnit = LinearUnit.Meters,
        OutGeometryType = GeometryType.Polygon,
        RadiusVertexCount = 10,
        SectorAngle = 5 * Math.PI / 3,
        SemiAxis1Length = 100000,
        SemiAxis2Length = 20000,
        StartDirection = 11 * Math.PI / 6
      Geometry geometry = GeometryEngine.Instance.GeodesicSector(param, SpatialReferences.WGS84);
      // geometry.IsEmpty = false
      polygon = geometry as Polygon;
      // polygon.PointCount = 68
      // polygon.PartCount = 1
    Requirements
