ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GetWKBSize Method
A combination of WkbExportFlags which determines how the geometry is exported.
The geometry to export.
Example
    GetWKBSize Method (GeometryEngine)
    Returns the size of the buffer in bytes that will be required to hold the OGC well-known binary version of the input geometry.
    Syntax
    Public Function GetWKBSize( _
       ByVal exportFlags As WkbExportFlags, _
       ByVal geometry As Geometry _
    ) As Integer
    Parameters
    exportFlags
    geometry
    Return Value
    The size of the buffer.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The method is not implemented for GeometryBag or Multipatch.
    The method is not implemented for geometry with curves.
    Remarks
    Does not support curves.
    Example
    Import and Export Geometries to well-known Binary
      // create a polyline
      List<Coordinate2D> coords = new List<Coordinate2D>
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      polyline = PolylineBuilderEx.CreatePolyline(
                  coords, SpatialReferences.WGS84);
      WkbExportFlags wkbExportFlags = WkbExportFlags.WkbExportDefaults;
      WkbImportFlags wkbImportFlags = WkbImportFlags.WkbImportDefaults;
      // export and import
      byte[] buffer = GeometryEngine.Instance.ExportToWKB(wkbExportFlags, polyline);
      geometry = GeometryEngine.Instance.ImportFromWKB(
                     wkbImportFlags, buffer, SpatialReferences.WGS84);
      Polyline importPolyline = geometry as Polyline;
      // alternatively, determine the size for the buffer
      int bufferSize = GeometryEngine.Instance.GetWKBSize(wkbExportFlags, polyline);
      buffer = new byte[bufferSize];
      // export
      bufferSize = GeometryEngine.Instance.ExportToWKB(
                      wkbExportFlags, polyline, ref buffer);
      // import
      importPolyline = GeometryEngine.Instance.ImportFromWKB(
               wkbImportFlags, buffer, SpatialReferences.WGS84) as Polyline;
    Requirements
