ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ImportFromJson Method
A combination of JsonImportFlags which determines how the geometry is imported.
The input JSON string. If the spatial reference information is in the string, then the output geometry will have the spatial reference associated with it.
Example
    ImportFromJson Method (GeometryEngine)
    Creates a geometry from the input JSON string.
    Syntax
    Public Function ImportFromJson( _
       ByVal importFlags As JsonImportFlags, _
       ByVal jsonString As String _
    ) As Geometry
    Parameters
    importFlags
    jsonString
    Return Value
    A Geometry that corresponds to the jsonString.
    Exceptions
    ExceptionDescription
    jsonString is null or empty.
    Example
    Import and Export Geometries to JSON
      // MapPoint
      string inputString =
        "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}";
      Geometry geometryFromJson = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString);
      MapPoint importPoint = geometryFromJson as MapPoint;
      // importPoint = 1, 2
      // importPoint.SpatialReference.WKid = 4326
      // use the MapPointBuilderEx convenience method
      MapPoint importPoint2 = MapPointBuilderEx.FromJson(inputString);
      // importPoint2 = 1, 2
      // impointPoint2.SpatialReference.Wkid = 4326
      string outputString = GeometryEngine.Instance.ExportToJson(
        JsonExportFlags.JsonExportDefaults, importPoint);
      // outputString =
      //   "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}"
      string outputString2 = importPoint.ToJson();
      inputString =
        "{\"spatialReference\":{\"wkid\":4326},\"z\":3,\"m\":4,\"x\":1,\"y\":2}";
      importPoint = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString) as MapPoint;
      // importPoint.HasM = true
      // importPoint.HasZ = true
      // importPoint.X = 1
      // importPoint.Y = 2
      // importPoint.M = 4
      // importPoint.Z = 3
      // export to json - skip spatial reference
                    JsonExportFlags.JsonExportSkipCRS, importPoint);
      // outputString = "{\"x\":1,\"y\":2,\"z\":3,\"m\":4}"
      // export from mappoint, skipping the sr - same as GeometryEngine.Instance.ExportToJson w JsonExportFlags.JsonExportSkipCRS
      outputString2 = importPoint.ToJson(true);
      // Multipoint
      List<Coordinate2D> coords = new List<Coordinate2D>()
      new Coordinate2D(100, 200),
      new Coordinate2D(201, 300),
      new Coordinate2D(301, 400),
      new Coordinate2D(401, 500)
      Multipoint multipointFromCoords = MultipointBuilderEx.CreateMultipoint(
        coords, SpatialReferences.WebMercator);
      inputString =
        "{\"points\":[[100,200],[201,300],[301,400],[401,500]],\"spatialReference\":{\"wkid\":3857}}";
      Multipoint importMultipoint =
               JsonImportFlags.JsonImportDefaults, inputString) as Multipoint;
      // importMultipoint.IsEqual(multipoint) = true
      ReadOnlyPointCollection pointsFromMultipoint = importMultipoint.Points;
      // points.Count = 4
      // points[0] = 100, 200
      // points[1] = 201, 300
      // points[2] = 301, 400
      // points[3] = 401, 500
      // use the MultipointbuilderEx convenience method
      Multipoint importMultipoint2 = MultipointBuilderEx.FromJson(inputString);
      // importMultipoint2.IsEqual(multipoint) = true
      // export to json
                      JsonExportFlags.JsonExportDefaults, multipointFromCoords);
      // outputString = inputString
      // or use the multipoint itself
      outputString2 = multipointFromCoords.ToJson();
      // Polyline
      Polyline polylineFromCoords = PolylineBuilderEx.CreatePolyline(
      // export without the spatial reference
                              JsonExportFlags.JsonExportSkipCRS, polylineFromCoords);
      // import
      geometry = GeometryEngine.Instance.ImportFromJson(
                   JsonImportFlags.JsonImportDefaults, outputString);
      Polyline importPolyline = geometryFromJson as Polyline;
      // importPolyline.SpatialReference = null
      pointsFromMultipoint = importPolyline.Points;
      // points.Count = 4
      // use the polylineBuilderEx convenience method
      Polyline importPolyline2 = PolylineBuilderEx.FromJson(outputString);
      // importPolyline2 = importPolyline
      outputString2 = importPolyline2.ToJson();
      // outputString2 = outputString
      // Polygon
      Polygon polygonFromCoords = PolygonBuilderEx.CreatePolygon(
                                JsonExportFlags.JsonExportSkipCRS, polygonFromCoords);
      // import
      Polygon importPolygon = geometry as Polygon;
      // importPolygon.SpatialReference = null
      pointsFromMultipoint = importPolygon.Points;
      // points.Count = 5
      // polygonBuilderEx convenience method
      Polygon importPolyon2 = PolygonBuilderEx.FromJson(outputString);
      // importPolygon2 = importPolygon
      // export from the polygon
      outputString2 = importPolyon2.ToJson(true);
      // Empty polygon
      polygon = PolygonBuilderEx.CreatePolygon(SpatialReferences.WebMercator);
                                     JsonExportFlags.JsonExportDefaults, polygon);
      importPolygon = GeometryEngine.Instance.ImportFromJson(
                          JsonImportFlags.JsonImportDefaults, outputString) as Polygon;
      // importPolygon.IsEmpty = true
      // importPolygon.SpatialReference.Wkid = 3857
    Requirements
