ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ImportFromWKB Method
A combination of WkbImportFlags which determines how the geometry is imported.
The well-known binary buffer. The buffer must be OGC compliant.
The spatial reference of the output geometry.
Example
    ImportFromWKB Method (GeometryEngine)
    Creates a geometry based on the contents of the input well-known binary buffer.
    Syntax
    Public Function ImportFromWKB( _
       ByVal importFlags As WkbImportFlags, _
       ByVal buffer() As Byte, _
       ByVal spatialReference As SpatialReference _
    ) As Geometry
    Parameters
    importFlags
    buffer
    spatialReference
    Return Value
    A Geometry that corresponds to the buffer.
    Example
    Import and Export Geometries to well-known Binary
      // create a polyline
      List<Coordinate2D> coords = new List<Coordinate2D>
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      polyline = PolylineBuilderEx.CreatePolyline(
                  coords, SpatialReferences.WGS84);
      WkbExportFlags wkbExportFlags = WkbExportFlags.WkbExportDefaults;
      WkbImportFlags wkbImportFlags = WkbImportFlags.WkbImportDefaults;
      // export and import
      byte[] buffer = GeometryEngine.Instance.ExportToWKB(wkbExportFlags, polyline);
      geometry = GeometryEngine.Instance.ImportFromWKB(
                     wkbImportFlags, buffer, SpatialReferences.WGS84);
      Polyline importPolyline = geometry as Polyline;
      // alternatively, determine the size for the buffer
      int bufferSize = GeometryEngine.Instance.GetWKBSize(wkbExportFlags, polyline);
      buffer = new byte[bufferSize];
      // export
      bufferSize = GeometryEngine.Instance.ExportToWKB(
                      wkbExportFlags, polyline, ref buffer);
      // import
      importPolyline = GeometryEngine.Instance.ImportFromWKB(
               wkbImportFlags, buffer, SpatialReferences.WGS84) as Polyline;
    Requirements
