ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ImportFromWKT Method
A combination of WktImportFlags which determines how the geometry is imported.
The input WKT string. The string must be OGC compliant.
The spatial reference of the output geometry.
Example
    ImportFromWKT Method (GeometryEngine)
    Creates a geometry from the input well-known text string.
    Syntax
    Parameters
    importFlags
    wktString
    spatialReference
    Return Value
    A Geometry that corresponds to the wktString.
    Exceptions
    ExceptionDescription
    wktString is null or empty.
    Example
    Import and Export Geometries to well-known Text
      // create a point with z, m
      MapPoint point = MapPointBuilderEx.CreateMapPoint(
               100, 200, 300, 400, SpatialReferences.WebMercator);
      // set the flags
      WktExportFlags wktExportFlags = WktExportFlags.WktExportDefaults;
      WktImportFlags wktImportFlags = WktImportFlags.WktImportDefaults;
      // export and import
      string wktString = GeometryEngine.Instance.ExportToWKT(wktExportFlags, point);
      MapPoint importPointGeom = GeometryEngine.Instance.ImportFromWKT(
            wktImportFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
      double x = importPointGeom.X;       // x = 100
      double y = importPointGeom.Y;       // y = 200
      bool hasZ = importPointGeom.HasZ;   // hasZ = true
      double z = importPointGeom.Z;       // z = 300
      bool hasM = importPointGeom.HasM;   // hasM = true
      double m = importPointGeom.M;       // m = 400
      // export without z
      WktExportFlags exportFlagsNoZ = WktExportFlags.WktExportStripZs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ, point);
      hasZ = importPointGeom.HasZ;  // hasZ = false
      z = importPointGeom.Z;        // z = 0
      // export without m
      WktExportFlags exportFlagsNoM = WktExportFlags.WktExportStripMs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoM, point);
      hasM = importPointGeom.HasM;  // hasM = false
      m = importPointGeom.M;        // m = Nan
      // export without z, m
        exportFlagsNoZ | exportFlagsNoM, point);
    Requirements
