ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Intersects Method
The base geometry.
The comparison geometry.
Example
    Intersects Method (GeometryEngine)
    Returns true if geometry1 and geometry2 intersect.
    Syntax
    Public Function Intersects( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    public bool Intersects(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if the two geometries intersect.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    Two geometries intersect if they have at least one point in common. Equivalent to not Disjoint.
    Example
    Intersection between two Polylines
      // determine intersection between two polylines
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
      Polyline line1 = PolylineBuilderEx.CreatePolyline(pts);
      List<MapPoint> pts2 =
        MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
      Polyline line2 = PolylineBuilderEx.CreatePolyline(pts2);
      bool intersects = GeometryEngine.Instance.Intersects(line1, line2);    // intersects = true
      Geometry g = GeometryEngine.Instance.Intersection(line1, line2, GeometryDimensionType.EsriGeometry0Dimension);
      Multipoint resultMultipoint = g as Multipoint;
      // result is a multiPoint that intersects at (2,2) and (4,2)
    Requirements
