ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Length Method
The input geometry.
Example
    Length Method (GeometryEngine)
    Gets the length for a specified geometry. This is a planar measurement using 2D Cartesian mathematics.
    Syntax
    Public Function Length( _
       ByVal geometry As Geometry _
    ) As Double
    public double Length(
       Geometry geometry
    Parameters
    geometry
    The input geometry.
    Return Value
    The calculated length in the same units as the geometry's spatial reference unit. If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Example
    Determine Length, Length3D of line
      MapPoint c1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3);
      MapPoint c2 = MapPointBuilderEx.CreateMapPoint(4, 2, 4);
      // line segment
      LineSegment line = LineBuilderEx.CreateLineSegment(c1, c2);
      double len = line.Length;     // = 3
      double len3D = line.Length3D;   // = Math.Sqrt(10)
      // polyline
      Polyline p = PolylineBuilderEx.CreatePolyline(line);
      double p_len = p.Length;        // = len = 3
      double p_len3D = p.Length3D;    // = len3D = Math.Sqrt(10)
      double ge_len = GeometryEngine.Instance.Length(p);      // = p_len = len = 3
      double ge_len3d = GeometryEngine.Instance.Length3D(p);    // = p_len3D = len3D = Math.Sqrt(10)
    Requirements
