ArcGIS.Core.Geometry Namespace / GeometryEngine Class / MovePointAlongLine Method
The multipart along which the point will be moved.
The distance to move the point.
Set the asRatio flag to be true if you want the distance to be a ratio of the curve length.
The offset distance.
Determines how and from where a segment is to be extended.
Example
    MovePointAlongLine Method (GeometryEngine)
    Constructs a point the specified distance along a polyline or polygon.
    Syntax
    Public Function MovePointAlongLine( _
       ByVal multipart As Multipart, _
       ByVal distanceAlong As Double, _
       ByVal asRatio As Boolean, _
       ByVal offset As Double, _
       ByVal extensionType As SegmentExtensionType _
    ) As MapPoint
    Parameters
    multipart
    distanceAlong
    asRatio
    offset
    extensionType
    Exceptions
    ExceptionDescription
    Multipart is null.
    Multipart is empty.
    Occurs if asRatio is true and the geometry has a 2d and 3d distance of 0.
    Remarks
    A positive offset distance will create a point on the right side of the curve and a negative offset will create a point on the left side of the curve.
    Example
    MovePointAlongLine
      LineSegment line = LineBuilderEx.CreateLineSegment(MapPointBuilderEx.CreateMapPoint(0, 3), MapPointBuilderEx.CreateMapPoint(5.0, 3.0));
      polyline = PolylineBuilderEx.CreatePolyline(line);
      bool simple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
      // ratio = false
      MapPoint pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 0.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 3.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, -1.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 4.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 2.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 1.0
      // ratio = true
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt = 2.5, 3.0
      // move past the line
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.NoExtension);
      // pt = 5.0, 3.0
      // move past the line with extension at "to" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt = 7.0, 3.0
      // negative distance with extension at "from" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, -2, false, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // pt = -2.0, 3.0
      // ratio = true
      // pt = 2.5, 3.0
      // line with Z
      List<Coordinate3D> coords3D = [new Coordinate3D(0, 0, 0), new Coordinate3D(1113195, 1118890, 5000)];
      Polyline polylineZ = PolylineBuilderEx.CreatePolyline(coords3D, SpatialReferences.WebMercator);
      // polylineZ.HasZ = true
      // ratio = true, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 556597.5
      // pt.Y = 559445
      // pt.Z = 2500
      // ratio = true, past the line with "to" extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 1.5, true, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt.X = 1669792.5
      // pt.Y = 1678335
      // pt.Z = 7500
      // ratio = true, negative distance past the line with no extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, -1.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 0
      // pt.Y = 0
      // pt.Z = -7500
      // polyline with Z but 2d distance = 0
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(5, 5, 0);
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      List<MapPoint> pts = [pt3, pt4];
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      // polyline.HasZ = true
      // polyline.Length3D = 10
      // polyline.Length = 0
      MapPoint result = GeometryEngine.Instance.MovePointAlongLine(polyline, 2, false, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 2
      // polyline with length2d = 0 and length3d = 0
      MapPoint pt5 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      MapPoint pt6 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      pts.Clear();
      pts.Add(pt5);
      pts.Add(pt6);
      // polyline.Length3D = 0
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 10
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // polyline with Z and M
      List<MapPoint> inputPoints =
          MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4),
        MapPointBuilderEx.CreateMapPoint(1, 2, 33, 44),
      Polyline polylineZM = PolylineBuilderEx.CreatePolyline(inputPoints, SpatialReferences.WGS84);
      // polylineZM.HasZ = true
      // polylineZM.HasM = true
      MapPoint pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 18, 24
      // ratio = true with offset
      pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.2, true, 2.23606797749979, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 9, 12
    Requirements
