ArcGIS.Core.Geometry Namespace / GeometryEngine Class / NormalizeCentralMeridian Method
The geometry that you want folded. If the input geometry is empty, then it is returned unchanged.
    NormalizeCentralMeridian Method (GeometryEngine)
    Folds the geometry into a range of 360 degrees. This may be necessary when wrap around is enabled on the map. If geometry is an Envelope then a Polygon will be returned unless the Envelope is empty in which case an empty Envelope will be returned.
    Syntax
    Public Function NormalizeCentralMeridian( _
       ByVal geometry As Geometry _
    ) As Geometry
    public Geometry NormalizeCentralMeridian(
       Geometry geometry
    Parameters
    geometry
    Return Value
    The folded geometry.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Geometry.SpatialReference is null.
    Requirements
