ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Overlaps Method
The base geometry.
The comparison geometry.
Example
    Overlaps Method (GeometryEngine)
    Returns true if geometry1 and geometry2 overlap.
    Syntax
    Public Function Overlaps( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    public bool Overlaps(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if if geometry1 and geometry2 overlap.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    Two geometries overlap if the dimension of each is equal to the dimension of their intersection, but the intersection itself is not equal to either one.
    GeometryEngine Overlaps
    Example
    Determine if geometries overlap
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1.5, 1.5);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(1.25, 1.75);
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(3, 1.5);
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(1.5, 2);
      // point and point overlap
      bool overlaps = GeometryEngine.Instance.Overlaps(pt1, pt2);        // overlaps = false
      overlaps = GeometryEngine.Instance.Overlaps(pt1, pt1);             // overlaps = false
        // Two geometries overlap if the region of their intersection is of the same dimension as the geometries involved and
        // is not equivalent to either of the geometries.
      List<MapPoint> pts = [pt1, pt2, pt3];
      List<MapPoint> pts2 = [pt2, pt3, pt4];
      // pt and line overlap
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);         // isSimple = true
      overlaps = GeometryEngine.Instance.Overlaps(polyline, pt1);                  // overlaps = false
      // line and line
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(pts2);
      isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline2);             // isSimple = true
      overlaps = GeometryEngine.Instance.Overlaps(polyline, polyline2);            // overlaps = true
    Requirements
