ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Project Method
The geometry to be projected. If the input geometry is empty, then an empty geometry with the output spatial reference is returned.
The spatial reference to which the geometry will be projected.
Example
    Project Method (GeometryEngine)
    Projects the given geometry to a new spatial reference. Same as GeometryEngine.ProjectEx(geometry, ProjectionTransformation.Create(geometry.SpatialReference, outputSpatialReference)); or, if both spatial references have vertical coordinate systems same as GeometryEngine.ProjectEx(geometry, ProjectionTransformation.CreateWithVertical(geometry.SpatialReference, outputSpatialReference));
    Syntax
    Parameters
    geometry
    Return Value
    The projected geometry.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    geometry.SpatialReference or output spatial reference is null.
    geometry.SpatialReference or output spatial reference is unknown coordinate system.
    Example
    Determine grid convergence for a SpatialReference at a given point
      Coordinate2D coordinate = new Coordinate2D(10, 30);
      double angle = SpatialReferences.WGS84.GetConvergenceAngle(coordinate);
      // angle = 0
      SpatialReference srUTM30N = SpatialReferenceBuilder.CreateSpatialReference(32630);
      coordinate.X = 500000;
      coordinate.Y = 550000;
      angle = srUTM30N.GetConvergenceAngle(coordinate);
      // angle = 0
      MapPoint pointWGS84 = MapPointBuilderEx.CreateMapPoint(10, 50, SpatialReferences.WGS84);
      MapPoint pointUTM30N = GeometryEngine.Instance.Project(
        pointWGS84, srUTM30N) as MapPoint;
      coordinate = (Coordinate2D)pointUTM30N;
      // get convergence angle and convert to degrees
      angle = srUTM30N.GetConvergenceAngle(coordinate) * 180 / Math.PI;
      // angle = 10.03
    Zoom to a specified point
      double x = -122.45;
      double y = 37.75;
      double buffer_size = 0.1;
      //Create a point
      var pt = MapPointBuilderEx.CreateMapPoint(x, y,
                     SpatialReferenceBuilder.CreateSpatialReference(4326));
      //Buffer it - for purpose of zoom
      var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
      //do we need to project the buffer polygon?
      if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference))
        //project the polygon
        poly = GeometryEngine.Instance.Project(poly, MapView.Active.Map.SpatialReference);
      // Must run on MCT.
      QueuedTask.Run(() =>
        //Zoom - add in a delay for animation effect
        MapView.Active.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Use Select or Search with a Spatial Query
    // Note: call within QueuedTask.Run()
      if (!featSceneLayer.HasAssociatedFeatureService)
        return;//no search or select
      //Select all features within the current map view
      var sz = MapView.Active.GetViewSize();
      var map_pt1 = MapView.Active.ClientToMap(new System.Windows.Point(0, sz.Height));
      var map_pt2 = MapView.Active.ClientToMap(new System.Windows.Point(sz.Width, 0));
      //Convert to an envelope
      var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, MapView.Active.Map.SpatialReference);
      //Project if needed to the layer spatial ref
      SpatialReference sr = null;
      using (var fc = featSceneLayer.GetFeatureClass())
      using (var fdef = fc.GetDefinition())
        sr = fdef.GetSpatialReference();
      var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
      //Set up a query filter
      var sf = new SpatialQueryFilter()
        FilterGeometry = env,
        SpatialRelationship = SpatialRelationship.Intersects,
        SubFields = "*"
      //Select against the feature service
      var select = featSceneLayer.Select(sf);
      if (select.GetCount() > 0)
        //enumerate over the selected features
        using (var rc = select.Search())
          while (rc.MoveNext())
            using (var feature = rc.Current as Feature)
              oid = feature.GetObjectID();
              //etc.
      MapView.Active.Map.ClearSelection();
    Project from WGS84 to WebMercator
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0, SpatialReferences.WGS84);
      Geometry result = GeometryEngine.Instance.Project(pt, SpatialReferences.WebMercator);
      MapPoint projectedPt = result as MapPoint;
    Project from WGS84
      // create the polygon
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(1.0, 2.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(2.0, 2.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(2.0, 1.0, SpatialReferences.WGS84),
      polygon = PolygonBuilderEx.CreatePolygon(pts);
      // ensure it is simple
      bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polygon);
      // create the spatial reference to project to
      SpatialReference northPole = SpatialReferenceBuilder.CreateSpatialReference(102018);   // north pole stereographic
      // project
      Geometry geometry = GeometryEngine.Instance.Project(polygon, northPole);
    Requirements
