ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Rotate Method
The geometry to rotate. If the geometry is an Envelope, then it will be converted to a polygon.
The origin around which the geometry will be rotated.
The rotation angle in radians.
Example
    Rotate Method (GeometryEngine)
    Rotates the geometry about the specified origin point.
    Syntax
    Public Function Rotate( _
       ByVal geometry As Geometry, _
       ByVal origin As MapPoint, _
       ByVal rotationAngle As Double _
    ) As Geometry
    Parameters
    geometry
    origin
    rotationAngle
    Return Value
    The rotated geometry. If the input geometry is an Envelope, then a polygon is returned. If the input geometry is empty, then an empty geometry is returned.
    Exceptions
    ExceptionDescription
    Either geometry or origin or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Example
    Rotate a MapPoint
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0);
      MapPoint rotatePt = MapPointBuilderEx.CreateMapPoint(3.0, 3.0);
      Geometry result = GeometryEngine.Instance.Rotate(pt, rotatePt, Math.PI / 2);
    // result point is (3, 1)
    Rotate a Polyline
      // rotate a polyline
      MapPoint fixedPt = MapPointBuilderEx.CreateMapPoint(3.0, 3.0);
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 5.0),
      MapPointBuilderEx.CreateMapPoint(5, 5),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      Polyline rotated = GeometryEngine.Instance.Rotate(polyline, fixedPt, Math.PI / 4) as Polyline;  // rotate 45 deg
    Rotate or Move the Annotation
      var oid = 1; //ObjectID of the annotation feature to modify
                   // Note: QueuedTask is required to access the AnnotationFeature
        //Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want...
        //var insp = new Inspector();
        //insp.Load(annotationLayer, oid);
        //var shape = insp["SHAPE"] as Polygon;
        //...wrong shape...
        //Instead, we must get the TextGraphic from the anno feature.
        //The TextGraphic shape will be the anno baseline...
        QueryFilter qf = new QueryFilter()
          WhereClause = "OBJECTID = 1"
        //annotationLayer is ~your~ Annotation layer
        using var rowCursor = annotationLayer.Search(qf);
        if (rowCursor.MoveNext())
          using (var annoFeature = rowCursor.Current as
          ArcGIS.Core.Data.Mapping.AnnotationFeature)
            var graphic = annoFeature.GetGraphic();
            var textGraphic = graphic as CIMTextGraphic;
            var textLine = textGraphic.Shape as Polyline;
            // rotate the shape 90 degrees
            var origin = GeometryEngine.Instance.Centroid(textLine);
            Geometry rotatedPolyline = GeometryEngine.Instance.Rotate(textLine, origin, System.Math.PI / 2);
            //Move the line 5 "units" in the x and y direction
            //GeometryEngine.Instance.Move(textLine, 5, 5);
            EditOperation op = new EditOperation();
            op.Name = "Change annotation angle";
            op.Modify(annotationLayer, oid, rotatedPolyline);
            op.Execute();
    Requirements
