ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Scale Method / Scale(Geometry,MapPoint,Double,Double) Method
The geometry to scale.
The origin around which the geometry will be scaled.
The scale factor along the X-axis.
The scale factor along the Y-axis.
    Scales the geometry about the specified origin.
    Syntax
    Public Overloads Function Scale( _
       ByVal geometry As Geometry, _
       ByVal origin As MapPoint, _
       ByVal sx As Double, _
       ByVal sy As Double _
    ) As Geometry
    Parameters
    geometry
    origin
    sx
    sy
    Return Value
    The scaled geometry. If the input geometry is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Either geometry or origin or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    GeometryEngine Scale
    Requirements
