ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Union Method / Union(IEnumerable<Geometry>) Method
The collection of geometries to union. If a geometry is an Envelope, it is converted to a Polygon.
    Constructs the set-theoretic union of the input geometries.
    Syntax
    Public Overloads Function Union( _
       ByVal geometries As IEnumerable(Of Geometry) _
    ) As Geometry
    Parameters
    geometries
    Return Value
    A geometry representing the union of the input geometries.
    Exceptions
    ExceptionDescription
    Geometries is null or empty.
    The method is not implemented for GeometryBag.
    Geometry is the wrong type for this operation. Cannot union geometries that have unequal dimensions. GeometryDimensionType
    Incompatible spatial references between the input geometries.
    One of the geometries has a spatial reference which is an image coordinate system.
    Remarks
    An exception is thrown if the SpatialReferences of the geometries are not equal or if the dimension of the geometries are not equal. This means that points and multipoints are considered to be the same type, and polygons and envelopes are considered to be the same type.
    GeometryEngine Union
    Requirements
