Public ReadOnly Property Points As ReadOnlyPointCollection
public ReadOnlyPointCollection Points {get;}
// get the points as a readonly Collection
//Refer to the initialization region for polyline creation
ReadOnlyPointCollection pts = polyline.Points;
int numPts = polyline.PointCount;
// OR get an enumeration of the points
IEnumerator<MapPoint> enumPts = polyline.Points.GetEnumerator();
// OR get the point coordinates as a readonly list of Coordinate2D
IReadOnlyList<Coordinate2D> coordinates = polyline.Copy2DCoordinatesToList();
// OR get the point coordinates as a readonly list of Coordinate3D
IReadOnlyList<Coordinate3D> coordinates3D = polyline.Copy3DCoordinatesToList();
// OR get a subset of the collection as Coordinate2D using preallocated memory
IList<Coordinate2D> coordinate2Ds = new List<Coordinate2D>(10); // allocate some space
ICollection<Coordinate2D> subsetCoordinates2D = coordinate2Ds; // assign
pts.Copy2DCoordinatesToList(1, 2, ref subsetCoordinates2D); // copy 2 elements from index 1 into the allocated list
// coordinate2Ds.Count = 2
// do something with the coordinate2Ds
// without allocating more space, obtain a different set of coordinates
pts.Copy2DCoordinatesToList(5, 9, ref subsetCoordinates2D); // copy 9 elements from index 5 into the allocated list
// coordinate2Ds.Count = 9
// OR get a subset of the collection as Coordinate3D using preallocated memory
IList<Coordinate3D> coordinate3Ds = new List<Coordinate3D>(15); // allocate some space
ICollection<Coordinate3D> subsetCoordinates3D = coordinate3Ds; // assign
pts.Copy3DCoordinatesToList(3, 5, ref subsetCoordinates3D); // copy 5 elements from index 3 into the allocated list
// coordinate3Ds.Count = 5
// OR get a subset of the collection as MapPoint using preallocated memory
IList<MapPoint> mapPoints = new List<MapPoint>(7); // allocate some space
ICollection<MapPoint> subsetMapPoint = mapPoints; // assign
pts.CopyPointsToList(1, 4, ref subsetMapPoint); // copy 4 elements from index 1 into the allocated list
// mapPoints.Count = 4
// Method 1: Get the start point of the polyline by converting the polyline
// into a collection of points and getting the first point
// sketchGeometry is a Polyline
// get the sketch as a point collection
Geometry sketchGeometry = polyline; // for example
var pointCol = ((Multipart)sketchGeometry).Points;
// Get the start point of the line
var firstPoint = pointCol[0];
// Method 2: Convert polyline into a collection of line segments
// and get the "StartPoint" of the first line segment.
var polylineGeom = sketchGeometry as ArcGIS.Core.Geometry.Polyline;
var polyLineParts = polylineGeom.Parts;
ReadOnlySegmentCollection polylineSegments = polyLineParts.First();
//get the first segment as a LineSegment
var firsLineSegment = polylineSegments.First() as LineSegment;
//Now get the start Point
var startPointOfSegment = firsLineSegment.StartPoint;
ReadOnlyPointCollection pts = polygon.Points;
// get an enumeration of the points
IEnumerator<MapPoint> enumPts = polygon.Points.GetEnumerator();
// get the point coordinates as a readonly list of Coordinate2D
IReadOnlyList<Coordinate2D> coordinates = polygon.Copy2DCoordinatesToList();
// get the point coordinates as a readonly list of Coordinate3D
IReadOnlyList<Coordinate3D> coordinates3D = polygon.Copy3DCoordinatesToList();
