ArcGIS.Core.Geometry Namespace / ReadOnlyPartCollection Class / GetEnumerator Method
Example
    GetEnumerator Method (ReadOnlyPartCollection)
    Returns an enumerator that iterates through the collection.
    Syntax
    Return Value
    A IEnumerator that can be used to iterate through the collection.
    Example
    Enumerate the parts of a Polyline
      ReadOnlyPartCollection polylineParts = polyline.Parts;
      // enumerate the segments to get the length
      double len = 0;
      IEnumerator<ReadOnlySegmentCollection> segmentsPolyline = polylineParts.GetEnumerator();
      while (segmentsPolyline.MoveNext())
        ReadOnlySegmentCollection seg = segmentsPolyline.Current;
        foreach (Segment s in seg)
          len += s.Length;
          // perhaps do something specific per segment type
          switch (s.SegmentType)
            case SegmentType.Line:
              break;
            case SegmentType.Bezier:
              break;
            case SegmentType.EllipticArc:
              break;
      // or use foreach pattern
      foreach (var part in polyline.Parts)
        foreach (var segment in part)
          len += segment.Length;
          switch (segment.SegmentType)
              break;
              break;
              break;
    Requirements
