ArcGIS.Core.Geometry Namespace / ReadOnlySegmentCollection Class
Members Example
    A read only collection of Segment classes.
    Object Model
    ReadOnlySegmentCollection ClassSegment Class
    Syntax
    Example
    Enumerate the parts of a Polyline
      ReadOnlyPartCollection polylineParts = polyline.Parts;
      // enumerate the segments to get the length
      double len = 0;
      IEnumerator<ReadOnlySegmentCollection> segmentsPolyline = polylineParts.GetEnumerator();
      while (segmentsPolyline.MoveNext())
        ReadOnlySegmentCollection seg = segmentsPolyline.Current;
        foreach (Segment s in seg)
          len += s.Length;
          // perhaps do something specific per segment type
          switch (s.SegmentType)
            case SegmentType.Line:
              break;
            case SegmentType.Bezier:
              break;
            case SegmentType.EllipticArc:
              break;
      // or use foreach pattern
      foreach (var part in polyline.Parts)
        foreach (var segment in part)
          len += segment.Length;
          switch (segment.SegmentType)
              break;
              break;
              break;
    StartPoint of a Polyline
      // Method 1: Get the start point of the polyline by converting the polyline
      //    into a collection of points and getting the first point
      // sketchGeometry is a Polyline
      // get the sketch as a point collection
      Geometry sketchGeometry = polyline; // for example
      var pointCol = ((Multipart)sketchGeometry).Points;
      // Get the start point of the line
      var firstPoint = pointCol[0];
      // Method 2: Convert polyline into a collection of line segments
      //   and get the "StartPoint" of the first line segment.
      var polylineGeom = sketchGeometry as ArcGIS.Core.Geometry.Polyline;
      var polyLineParts = polylineGeom.Parts;
      ReadOnlySegmentCollection polylineSegments = polyLineParts.First();
      //get the first segment as a LineSegment
      var firsLineSegment = polylineSegments.First() as LineSegment;
      //Now get the start Point
      var startPointOfSegment = firsLineSegment.StartPoint;
    Enumerate the parts of a Polygon
      int numSegments = 0;
      IEnumerator<ReadOnlySegmentCollection> segments = polygon.Parts.GetEnumerator();
      while (segments.MoveNext())
        ReadOnlySegmentCollection seg = segments.Current;
        numSegments += seg.Count;
          // do something with the segment
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Geometry.ReadOnlySegmentCollection
    Requirements
