// Method 1: Get the start point of the polyline by converting the polyline
// into a collection of points and getting the first point
// sketchGeometry is a Polyline
// get the sketch as a point collection
Geometry sketchGeometry = polyline; // for example
var pointCol = ((Multipart)sketchGeometry).Points;
// Get the start point of the line
var firstPoint = pointCol[0];
// Method 2: Convert polyline into a collection of line segments
// and get the "StartPoint" of the first line segment.
var polylineGeom = sketchGeometry as ArcGIS.Core.Geometry.Polyline;
var polyLineParts = polylineGeom.Parts;
ReadOnlySegmentCollection polylineSegments = polyLineParts.First();
//get the first segment as a LineSegment
var firsLineSegment = polylineSegments.First() as LineSegment;
//Now get the start Point
var startPointOfSegment = firsLineSegment.StartPoint;
PolylineBuilderEx polylineBuilder = new PolylineBuilderEx(polyline);
polylineBuilder.HasZ = true;
// The HasZ property is set to true for all the points in
// polyline3D when you call ToGeometry().
Polyline polyline3D = polylineBuilder.ToGeometry();
// For this example, create Z-values.
// You may want to pass them in as a parameter.
int numPoints = polyline3D.PointCount;
double[] zValues = new double[numPoints];
for (int i = 0; i < numPoints; i++)
zValues[i] = i % 2 == 0 ? 2 : 1;
// We need to know at which point index each part starts
int partPointIndex = 0;
int numParts = polyline3D.PartCount;
for (int i = 0; i < numParts; i++)
var part = polyline3D.Parts[i];
int numSegmentsInPolyline3D = part.Count;
for (int j = 0; j < numSegmentsInPolyline3D; j++)
Segment segment = part[j];
MapPointBuilderEx pointBuilder = new MapPointBuilderEx(segment.StartPoint);
pointBuilder.Z = zValues[partPointIndex++];
MapPoint startPoint = pointBuilder.ToGeometry();
// Make sure that the end point of this segment is the same as the start point of the next segment
pointBuilder = new MapPointBuilderEx(segment.EndPoint);
pointBuilder.Z = zValues[partPointIndex];
MapPoint endPoint = pointBuilder.ToGeometry();
SegmentType segmentType = segment.SegmentType;
SegmentBuilderEx segmentBuilder = null;
switch (segmentType)
case SegmentType.Line:
segmentBuilder = new LineBuilderEx((LineSegment)segment);
break;
case SegmentType.Bezier:
segmentBuilder = new CubicBezierBuilderEx((CubicBezierSegment)segment);
break;
case SegmentType.EllipticArc:
segmentBuilder = new EllipticArcBuilderEx((EllipticArcSegment)segment);
break;
// Only change the start and end point which now have Z-values set.
// This will preserve the curve if the segment is an EllipticArcSegment or CubicBezierSegment.
segmentBuilder.StartPoint = startPoint;
segmentBuilder.EndPoint = endPoint;
segment = segmentBuilder.ToSegment();
polylineBuilder.ReplaceSegment(i, j, segment);
// Move point index for the next part
partPointIndex++;
// retrieve the bezier curve's control points
CubicBezierSegment cb = CubicBezierBuilderEx.CreateCubicBezierSegment(bezierSegment);
MapPoint startPt = cb.StartPoint;
Coordinate2D ctrlPt1 = cb.ControlPoint1;
Coordinate2D ctrlPt2 = cb.ControlPoint2;
MapPoint endPt = cb.EndPoint;
bool isCurve = cb.IsCurve;
double len = cb.Length;
// retrieve the curve's control points
EllipticArcSegment arc = EllipticArcBuilderEx.CreateEllipticArcSegment(ellipticArcSegment);
MapPoint startPt = arc.StartPoint;
MapPoint endPt = arc.EndPoint;
Coordinate2D centerPt = arc.CenterPoint;
bool isCircular = arc.IsCircular;
bool isMinor = arc.IsMinor;
bool isCounterClockwise = arc.IsCounterClockwise;
bool isCurve = arc.IsCurve;
double len = arc.Length;
double ratio = arc.MinorMajorRatio;
double semiMajorAxis, semiMinorAxis;
// get the axes
arc.GetAxes(out semiMajorAxis, out semiMinorAxis);
// or use the properties
// semiMajorAxis = arc.SemiMajorAxis;
// semiMinorAxis = arc.SemiMinorAxis;
double startAngle, centralAngle, rotationAngle;
// or use QueryCoords to get complete information
arc.QueryCoords(out centerPt, out startAngle, out centralAngle, out rotationAngle, out semiMajorAxis, out semiMinorAxis);
// use properties to get angle information
//double endAngle = arc.EndAngle;
//centralAngle = arc.CentralAngle;
//rotationAngle = arc.RotationAngle;
//startAngle = arc.StartAngle;
